pjw73nh
- March 20, 2011
- 08 LTD
Does the 6R60 transmission have any "anti-damage" safeguards built in to it?
I recently solved a misfiring issue with my 08 4.6 LTD (bad coil). When it would act up and miss was under heavy load. Like stomping on the accelerator to pass a slower vehicle. Or going up a steep hill and having it down shift.
What puzzles me is that when this misfire issue was happening, it would rev high, slam into what ever gear is was searching for, chirp the back tires, the traction control light would flash for a bit, and the engine would then be revving very high as if it was in neutral. Like the trans was quickly and temporarily disconnected from the engine.
Yet, as soon as I let off the gas pedal and the rpms came back into a normal range, it would fall into gear as if nothing had happened and continue on its merry way until the next occurrence.
It threw my diagnosis off for a bit because until it finally set a P0301 code (after many occurrences), I was thinking it might be a transmission or TCM issue.
So, my question stands. Does the 6R60 have any safeguards against self destruction?
Thanks.
Thanks.
