Tech By Trade
- May 2, 2012
- Your mom's house
- 07 Sport Trac
Also, is the red light blinking on your dash, and if so, what is the pattern?
It says check charging system in place of where the digital odometer reading is. I'm goin g to go to Harbor Freight to purchase a load tester.Also, is the red light blinking on your dash, and if so, what is the pattern?
@dacaur2A harbor freight load tester can be gotten for about $20.... For someone with 3-4 vehichles in a household (including kids cars) its a pretty good investment. Heck, for $20 I would buy one just to avoid having to pull the battery and drive it down to be tested....
@dacaur2A load tester is not a complicated device. Literally all it is is a volt meter and a resistor with a big enough heatsink to be able to handle a few hundred amps for 10 seconds....
Starter has been changed that's why it's believed to be the battery.@dacaur2
Which is exactly the effect of cranking an engine without starting it, no? What are we trying to "prove out" a battery, or bum starter? imp
According to the OP, it wont turn over at all, just clicks.....@dacaur2
@dacaur2According to the OP, it wont turn over at all, just clicks.....
@dacaur2
Don't know why no one "buys" the hydrometer idea. One bad cell in the battery limits high current flow, and often will not turn the starter, but will light lights. About $10, best little gadget available for battery testing, nothing else will reveal a bad cell. imp
@07EddyBThey basically went out when batteries became maintenance free. Yes - you can rip the caps off but can you get them back on securely?
Also, a battery tester is crucial. Yes - you can test the battery with a standard meter while cranking the starter and see how low it goes. But - you are missing a crucial piece of information - is the battery drop because it was bad or was a bad starter pulling a greater load than it should?
You never get actionable information testing two suspect devices together.
When I turn the key, all lights go out, disconnect the cables and reconnect, and the lights are back on. I'm baffledhave you had the battery load tested? Now that the battery has been charged what does the voltage show while its just sitting there? Have someone watch the voltmeter on the batty while you turn the key, does the voltage drop and how much?
No I haven't but I'll give that a try. ThanksHave you replaced the negative battery post connector? I know it sounds elementary, but it's happened to me 3 times in 2 different Explorers. All else was working fine.
