ColoGuy
- September 29, 2019
- Blanca, Colorado
- 92 97 09 Explorers
leaking coolant from exhaust manifold side of passenger head gasket - from appearances. It is so crowded that I can't see the exact source. Could be a freeze plug or a plastic thingamajig for all I know.
Happened while towing 3600 pounds incl. the trailer. Temp. was about 70F. Ideal conditions. Engine mileage: 112,000. I've towed three times more weight ten times further with a similar though much higher mileage engine with no issues.
The leak is "moderate" - maybe a cup every 10 minutes. Not mixing with engine oil yet.
Had this motor installed by mechanic 1/2 year ago. It was flawless until tow job involving 160 miles.
Oddly I can't find pertinent youtube videos. Doesn't seem to be a common problem.
Thinking it may be related to the recent engine swap. This was the first "hard work" the newer engine has received.
The overflow box somehow self drained while sitting for three weeks. The fluid just seemingly disappeared, I was gone most of the time. The leak doesn't get going until driving. Just idling with no driving? No leaks happen.
Looking for alternatives. Thanks in advance for thoughtful help.
