remvalenzuela
- November 23, 2018
- Houston, TX
- 2011 Explorer Limited
Hi All,
I joined this forum today, hoping to get some troubleshooting suggestions from the smart folks here... here's my issue... (sorry for the length)...
Was getting sluggish / studdering performance on my 2011 Explorer Limited has 3.5L engine. Recently, engine light came on, had to keep driving home, about 300 miles, but engine light went back off. The next day, wife takes it out and CEL comes on again, but this time, engine is sputtering bad. Wife drives it back to the house. When i get to it after work, i pull codes P0305 and P0303. Which are for misfire on 3 & 5. And noticed that the car doesn't start anymore, it cranks a couple times then clunks. So, since we just reached 100k miles, i figure, its either ignition coil, spark plugs or PCValve.
Today, I replaced all of the Coils, spark plugs and, the PCValve. But when i went to start it after replacing them, same happens...cranks a couple times, then clunks to a stop. But this time i notice, that when it does that the dash graphics appear to reset. If i push the start button again, it immediately clunks and dash resets. If i wait a min or so and try again, it will crank a couple times and then clunk/reset. However about 10% of the time it will crank a while and do a really rough start and die eventually.
I pulled codes again, but Torque says they are historical codes: P0305/P0304 and P0300.
Im at a loss, but I fear its a PCM issue? Any thoughts?
Thanks!
Thanks!
