2012 service power steering | Ford Explorer Forums
matt+hies28
Brocton
2012 explorer xlt
Service power steering, service stabilitrack and turn signals not working. All of a sudden I lost power steering at the same time stabilitrack light came on and also turn signals don't stay on. I'm thinking it's the rack and pinion but want to be sure. Is this covered under recall?
Welcome to the Forum. :wave:
Are you the original owner? If so, you should have received a letter about the issue some 5 or so years ago.
Check out this post; 2011 - 2018 Explorer Power Steering Issue
I would also advise checking with your dealer and looking up your Ford account to see if this is an outstanding recall.
I will call dealer in the morning. I'm thinking the steering angle sensor is bad? How would I test this?
It is not under warranty and I am again having this issue. When it did this 3 months ago I disconnected battery and re moved steering angle sensor I put it back together and it worked for almost 3 months. I tried again and I still have no power steering turn signals advance track either. How can I determine if it is rack and pinion, angle sensor or steering module?
