2013 sunroof and screen issues | Ford Explorer Forums
Jason4606
Birmingham, AL
2013 Explorer 4WD Limited
Hi All,
I had a sunroof leak that I suspect was due to a driver-side front drain clog. (Based on the way vehicle was parked)
Wanted to clean the lines, but the glass won't slide. Sunscreen was still working, so I checked fuses then swapped the 2 motors to make sure it was the glass motor and not something else. It didn't work, and now the sunscreen won't operate either after that motor was reinstalled. (Neither motor will even run when disconnected from the tracks.)
Motor control boards show no signs of water ingress, corrosion, or failed components and motors run with 12VDC applied directly to terminals. All 3 switches, the constant and delayed ACC power, and ground tested at the motor connectors are all fine.
I've tried the reset procedures multiple times for glass and sunscreen with motors fully installed and also free from tracks, just to see if either would ever spin. Nothing.
I'm at a loss for what else it could possibly be. But have a really hard time believing the sunscreen motor would stop working in the time it took to remove and reinstall.
Any other ideas? Is there a no-load feature in the controller that might sense the motors are disconnected from the tracks? Doubt it. But no details available that I can find.
Will be trading/selling this vehicle soon. Don't want to just start throwing money at it without a good idea what the issue is first.
Thanks!
Welcome to the Forum. :wave:
You seem to have done everything that would have recommended. I don't know why the original shade motor isn't working when you put it back in place. Are you able to check to verify that there is power going to it?
Thanks!
Unfortunately, yes. There is power and ground, and the switched input power for open/close/tilt measured at the back of both motor connectors.
Connectors don’t appear to have any corrosion and after unplugging/plugging several times assume would help wipe the contacts.
At a complete loss. Cant stand the thought of ordering 2 motors without knowing for sure. But not sure what else to try.
Hi Jason. I'm not familiar with the 2 motor setup other than knowing they can be interchanged. Is it possible to remove the one that was working for the shade and leave it connected to its power source without it trying to drive the shade and then see if it works? Somewhat similar to a bench test.
Tried "loose" and installed. Nothing.
Doesn't make any sense. Feel like there's something silly. But with voltage at terminals on motor, including the switch inputs, I can't think of anything else to try.
I replaced mine on a '13 and found that one motor didn't work when it was the only one installed. Seems like it wanted to have both in line and plugged in. It didn't seem to matter if one was defective, as long as there were two present.
ANNNND, the first motor I tried was a Chinese knockoff. It wouldn't program. Everything started working when I began using Motorcraft (Ford) parts. With both motors in place. Since then I've only used OEM parts.
I also clipped off the end of the drain tubes in the front fender wells. This removed the crimped ends. The crimped ends were catching the debris. They were a bit of trouble to get to, but I have had NO MORE drain tube problems and everything is free flowing.
Please take my suggestions with a grain of salt. My memory isn't what it used to be.
IF you decide to order a new motor(s), Levittown Ford is a forum vendor and offers members a discount. Benny is very helpful.
I believe that #12 is the part.
