2014 SPORT sunroof initialization needed | Ford Explorer Forums - Serious Explorations
gbgoss17
Green Bay
2014 Ford Explorer Sport
I've replaced my sunroof motor and it does work with some weird issues.
Push tilt acts like one button slide open
Pull tilt nothing happens
Push slide --sunroof opens but only holding the button the entire time
Pull slide closes but holding the button the entire time.
Non Motorcraft motor fyi
I've tired a bunch of reset processes but none of them seem to work.
Would be nice to have it operate as it should. Any help would be awesome.
If you have already tried the above then the motor you have may not be "programmable" like the factory unit. The shade and glass are separate motors. Did you only replace one?
Yes the drivers side window slide motor
Did you ever get this to initialize correctly? I am having the same issue.
Welcome to the Forum. :wave:
FYI, the member you quoted was last seen here on August 20, 2022 so may no longer be following.
Thanks Peter. 🤙🏽
Same here. Ordered one from Amazon and having same issues
Is it a genuine Ford product?
FYI, Levittown Ford is a forum vendor and offers members a discount. If you plan to order one, here is the info;
