lucky644
- August 19, 2023
- Alberta
- 2015 Ford Explorer LTD.
I have a 2015 Ford Explorer /w the 3.5l Ti-VCT at 230,000KM that I bought used, so I am not sure what past work has been done on it apart from what I've done myself.
It's currently stalling sometimes when it's warmed up, I'd had it stall out while slowing down and stall while sitting idle in drive on the brake.
It finally threw a check engine light, the codes were P0017 and P0012. What I'm not sure about is whether these codes are a symptom of the stalling, or they are the root cause of the stalling.
I've done some searching, but I haven't found anything concrete. I'm trying to figure out where to start looking.
Should I try replacing the camshaft timing sensor? Could it be something fuel-related and it's running lean and stalling and thus causing the codes?
I have access to forscan, and I noticed the long-term fuel trim are +12FT1 and +16FT2 while idling. Short term fuel trim seem to bounce around a lot but generally stay over +5.
If anyone has any advice on what to look at or maybe what to check with forscan it would be much appreciated, thanks!
