2015 Fog light replacement | Ford Explorer Forums
Lumpy315
Woodbridge Virginia
2015 Explorer Sport
Is there a DIY on how to replace 2015 explorer fog light? I just found my drivers side broken.
I replaced one in my 2011 this past year. Was very easy. Drive car on ramps. Disconnect plug to light assy. 4 screws hold it in. They are a little tight to get to all 4 but doable with right length socket extensions and swivels. Might have been an 8mm or 10mm bolt head. 30 min job.
Keith
Its quite easy. You need to remove the front part of the inner fender liner to access the screws.
I replaced mine with aftermarket LED lights. I made some pictured, maybe these will help you, but I removed the entire front bumper, but you will not need to do this.
LED DRL, Fog and Positioning Lights
Welcome to the Forum.:wave:
