dave87e
- September 23, 2022
- Georgia
- 2015 3.5L Ecoboost
I just got this vehicle back from a water pump explosion and it flat out died and refused to start after driving fine for an hour and going in a store. I hooked up FORScan and got the following:
I am thinking its a Fuel Pressure sensor with the P0087, but I am not sure why its accompanied by the P008A, Any help would be appreciated.
Code: P0087 - Fuel Rail/System Pressure - Too Low (Bank 1)
Status:
- Previously Set DTC - Not Present at Time of Request
- Malfunction Indicator Lamp is On for this DTC
- Test not complete
Module: Powertrain Control Module
Freeze Frame #1:
Freeze Frame #2:
-EVENT_TIME: 206115457 s (Fri Sep 23 17:24:01 2022) - Event time
-TOTAL_DISTANCE: 111325 km - Total Distance
-FUELSYS: OL - Fault - Fuel System Status (Open/Closed Loop)
-LOAD: 86.27 % - Calculated Load Value
-ECT: 94 °C - Engine coolant temperature
-SHRTFT1: 0.00 % - Short term fuel trim 1
-LONGFT1: 2.34 % - Long term fuel trim 1
-SHRTFT2: 0.00 % - Short term fuel trim 2
-LONGFT2: 2.34 % - Long term fuel trim 2
-MAP: 90.0 kPa - Manifold absolute pressure sensor
-RPM: 603 1/min - Engine Revolutions Per Minute
-VSS: 0.0 km/h - Vehicle Speed
-SPARKADV: -3.50 ° - Spark Advance
-IAT: 50 °C - Intake Air Temperature
-RUNTM: 10 s - Time Since Engine Start
-EVAP_PCT: 0.00 % - Commanded Evaporative Purge
-FLI: 89.41 % - Fuel Level
-FTP_H20: 0 - Fuel Tank Pressure displayed as inches of water
-BARO: 99.0 kPa - Barometric pressure
-VPWR: 13.53 V - Control Module Voltage
-TP_REL: 7.45 % - Relative Throttle Position
-TAC_PCT: 12.16 % - Commanded Throttle Actuator Control
-RPMDSD: 850 1/min - Desired Idle Speed RPM
-O2S12: 0.35 V - Heated Exhaust Gas Oxygen Sensor (bank 1, sensor 2)
-O2S22: 0.32 V - Heated Exhaust Gas Oxygen Sensor (bank 2, sensor 2)
-TQ_CNTRL: None Requested - Torque Control Requested
-APP_FLT: No Fault - Accelerator Pedal Position Sensor Status
-CHT_F: No Fault - Cylinder Head Temperature Sensor Status
-CHTIL: Off - Cylinder Head Temperature Indicator Lamp
-IAT_F: No Fault - Inlet Air Temperature Sensor Status
-ETC_TRIM_LRN: Yes - Throttle Angle Offset has Learned
-MISFIRE: No - Engine Misfire currently detected
-TP_F: No Fault - Throttle Position Sensor Status
-FF_LRND: No - Inferred Flex Fuel Learned
-MP_LRN: Yes - Misfire Profile Correction Learned
-MAF_F: No Fault - Mass Air Flow Sensor Status
-MAP_F: No Fault - Manifold Absolute Pressure Sensor Status
-OTS_STAT: Enabled - One-Touch Start Status
-PCVHC_F: No Fault - PCV Heater Control Status
-SMC_MON: Off - Starter Motor Control Output Detected
-STRT_RLY: Disabled - Starter Motor Relay Enable
-APP1: 0.76 V - Accelerator pedal position sensor 1
-APP2: 0.39 V - Accelerator pedal position sensor 2
-TP1: 4.04 V - Throttle Position Sensor 1
-TP2: 1.32 V - Throttle Position Sensor 2
-GEAR: 1 - Gear Commanded
-GEAR_OSC: 1 - Gear Command by Output State Control
-TSS_SRC: 775 1/min - Actual Turbine Shaft Speed
-OSS_SRC: 0 1/min - Actual Output Shaft Speed
-TFT: 91 °C - Transmission Fluid Temperature
-TR: Park - Transmission range
Code: P008A - Low Pressure Fuel System Pressure - Too Low
Status:
- DTC Maturing - Intermittent at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
- Test not complete
Freeze Frame #1:
Freeze Frame #2:
-EVENT_TIME: 206115460 s (Fri Sep 23 17:24:04 2022) - Event time
-LOAD: 96.47 % - Calculated Load Value
-ECT: 93 °C - Engine coolant temperature
-LONGFT1: 3.13 % - Long term fuel trim 1
-LONGFT2: 3.13 % - Long term fuel trim 2
-MAP: 96.0 kPa - Manifold absolute pressure sensor
-RPM: 540 1/min - Engine Revolutions Per Minute
-SPARKADV: -5.50 ° - Spark Advance
-IAT: 49 °C - Intake Air Temperature
-RUNTM: 13 s - Time Since Engine Start
-FLI: 89.80 % - Fuel Level
-VPWR: 13.56 V - Control Module Voltage
-TP_REL: 10.20 % - Relative Throttle Position
-TAC_PCT: 14.12 % - Commanded Throttle Actuator Control
-O2S12: 0.32 V - Heated Exhaust Gas Oxygen Sensor (bank 1, sensor 2)
-O2S22: 0.29 V - Heated Exhaust Gas Oxygen Sensor (bank 2, sensor 2)
-TP1: 3.92 V - Throttle Position Sensor 1
-TP2: 1.55 V - Throttle Position Sensor 2
-TSS_SRC: 715 1/min - Actual Turbine Shaft Speed
Status:
- Test not complete
Freeze Frame #1:
Freeze Frame #2:
Status:
- Test not complete
Freeze Frame #1:
Freeze Frame #2:
