2015 ford explorer sport Mass Airflow Sensor location? | Ford Explorer Forums
johnnysoulja88
Philadelphia
! I can't find it on my 2015 Ford Explorer Sport only see the MAP Sensor I'm losing my mind man.
Sports don't have a mass air flow sensor, they have two map sensors and at least one air temp sensor in the airbox, the map sensors are on the intake pipe right before the throttle body and in the middle of the upper intake manifold on top with only one bolt (even though it has 2 holes) only NAs have a mass air flow sensor iirc.
thanks, so I took it to AutoZone, and they told me the only thing wrong with my Explorer is the Mass Airflow Sensor location need to be replaced. so, I'm just lost at what do do now.
https://www.autozone.com/engine-man...i-new-mass-air-flow-sensor-maf0112/675133_0_0 AutoZone gave me this part to put in.
Did they give you the actual code should be a P0###, I always take a photo with my phone and research after if it's not clear cut what I need to do.
yea maybe I need to replace the MAP then? I'm so lost lol.
Are there any symptoms specific to the problem and/or did they give you that print out they do now? I'd take it back and get it re-scanned worst case.
Friday morning I went and got a oil change I drove my truck at least 15 miles after the oil change then the next day I drove about 7 miles then my truck start shaking bad then oil light came on then my truck shut off next day it came back on like nothing happened I took it to auto zone they told me I need a air flow mass sensor but I been knew I need that but I wasn’t having problems until now after I got the oil change
Never go back to AutoZone again and expect them to diagnose your vehicle.
