2016 Limited AC Compressor Won't Engage Except When Jumped | Page 3 | Ford Explorer Forums
I found a connector which appears to be the one that goes to the sensor, and I stuck a 2.2K resistor in it. No change.
Can you find the output schematics of circuits for the AC controller? Before digging deep into hard to reach wiring and parts, I'd start with the main AC module. See which is the output wire/circuit that leads to the compressor, and what voltage it should be. Check that first before spending large amounts of time or money on other items.
The sensors and switches are more reliable than the electronics of modules. If guessing the module is more suspect, and there are many sources for repair services for them. I'm just suggesting to eliminate that possible expensive and common issue, which will be more likely as the parts get older.
Again, I fixed my 91 Lincoln same issue, which was the AC controller(EATC), by not fixing the EATC itself, but adding a relay which uses the existing insufficient signal. I don't claim it's the best answer for every case, but the high current through the old model controllers was a bad(old) idea. Repairing those old electronics is hard to find help with, and expensive, my cost for the relay was about $8, plus my time(about 15 minutes(plus prior 2+ hours of diagnosis time)).
So be sure your AC controls are producing the proper output signal to the AC clutch. If it's right, then you are narrowing down the problem to the wires and components in between, on that circuit.
Why did you use a resistor? Is 2.2Kohm the resistance of the evap temp sensor? Isn't it just a closed circuit that opens when the temp drops to 32? Like, use a piece of wire and jumper it.
In that video the guy uses a new evap temp sensor and just leaves it dangling
You have to have the right resistance or the A/C will shut off.
As resistors go, 2.2K is small. There is no "right resistance." There is a range of resistances that will work. I used 2.2K because it was close to the value that worked for someone else.
The car started overheating very quickly, and today it was impossible to drive it home. Now it's at a shop, and it's someone else's problem. I'll come back and let people know what the problem turned out to be.
Cool man, nice troubleshooting with ya. Curious to hear what it is.
Best of luck with the repairs. Electrical gremlins are the toughest to deal with, but we try to help.
Did you ever find out the answer to this? My 2016 limited is doing the same thing, had it at the dealership for a month to get the APIM module replaced and when we picked it up, the A/C compressor wouldn’t kick on.
Welcome to the Forum. :wave:
The OP mentioned the A/C would work when the vehicle's battery was "jumped". Is that the same as yours or does the A/C not work at all?
I know this is 4 years old but Did you ever figure out your problem? I have a 2015 with the EXACT same issues you are having
We're still waiting as to what the problem was.:D
