2016 PIU FORScan Help? | Ford Explorer Forums
Street1049
Wichita Falls, Texas
2016 PIU
Honestly still trying to get a hang of the basics. A bit overwhelmed / unsure where to start when it comes to changing things to get results. Using the Windows version with ELM327 and MS CAN switch.
Mostly looking to start out by disabling the "Police" rear hatch configuration to make it unlock normally and get a set of key-less remotes working, and just need a little steering in the right direction.
There are 2 threads in this section - one for 2015 and earlier and one for 2016 an later PIUs that have the info you seek.
You can activate the RKE function with Forscan, but it cannot program remotes for 2016+. You will need a trip to a dealer to get your remotes programmed to the vehicle so they function.
