BobT2k
- July 1, 2019
- Whippany
- 2023 Explorer ST
- Callsign
- N2RKU
So I've been having an issue for a while and I'm not really sure what its related to... i don't think its a problem with the as-built vehicle, but probably some combination of a part / service / me not being able to explain it to the service... so posting it here since I've seen some good feedback when others have had problems.
The basic issue is that I've noticed a severe degradation in handling back in the December / January timeframe... at first when turning right at highway speeds I'd notice the Explorer start to sway and/or track back and forth across the lane... and sometimes the sway would continue when heading strait after that. I'd also notice when going strait that it would track fine, then steer to one side of the lane or anther...
After the most recent service, at least so far, I'm not noticing the turning issue as month, but am noticing the the sway when going straight even more.. AND now noticing that when i accelerate the car "twists"... the rear feels as if it "slides" to the left... then when take foot of the gas notice it twist back.
during the most recent service, they did alignment and noted the rear right wheel was way out alignment. Part of the reason we started digging deeper was that the rear right tire wore (Evenly) much faster than the rest of the car... it lasted only 10k and was down to the indicator. the left tire was in better shape though close behind it. the front tires showed normal ware.
I mentioned this started in December/January... in December there was a warranty service where they had to replace one the rear axle... bushing were bad. Started to noticed the car feeling "looser" around then, but, also noted the tires were reaching the end of their life... In January I had the tires replaced (got 36k out of the stock streetpack tires) and replaced them with Michelin Pilot Sport A/S4's. Really started to notice the the swaying then. In february in for service .. dealer said front axles and replaced them under warranty... when i left the alignment was off (it drove straight, but the steering wheel was about 5% off-center to do so.. they fixed that the next dat and while the care was not back to where it was in the fall, it was better (or i got used to it.) drove about 7k after that until this month when went in for an oil change and noted that the rear right was worn (funny thing is i was watching the tires for a funny wear pattern... which it didn't have, but that's the one tire i rarely walked past so didn't notice the wear. had the rear tires replaced under michelline warranty (actually on the front now... last generation on the back... and that's when tehy did the most recent alignment). When they did the alignment, they also checked for suspension issues and said there were none.
So sorry for the long winded email , if nothing else it was cathartic for me to write it down... but any suggestions on what to push them to look at?
- Could this be a while bearing? there's been no sounds indicating it... but it certainly seems like something is "loose"
- should i look for a differently place to check the alignment? I'm starting to wonder about the dealer's capability when it comes to alignments...
-could this be a sway bar issue?
-could this be a strut issue?
- Are the Michelin Sport A/S 4 tires that much different than the stock pirelli's? I expected to feel the road more, and get some trolly tracking... but the sway / rear end twist just makes hte car feel too loose
And if i do need to switch locations, anyone have a good service center in north-jersey they would recommend talking to?
