2020 ST Chassis Photos | Ford Explorer Forums
Rick
Pumpkin Pilot
Staff member
Admin
Wayoutin, Aridzona
'93 XL '20 ST
Callsign
AB7FH
I put our ST on my lift today and photographed the undercarriage while everything is still nice and clean. I am providing this for future reference.
I was surprised at the lower control arm setup. I have never before seen a two piece lower control arms or two lower ball joints before.
Nice FoMoCo parts I like how tucked up everything is alot of ground clearance.
My merkur scorpio has the same looking rubber puck in the driveshaft. It left me walking once.
View attachment 325568View attachment 325569View attachment 325570View attachment 325571View attachment 325572View attachment 325573View attachment 325574View attachment 325575View attachment 325576View attachment 325577
This is how it will look after a year and 12,000 miles!
wow hbalek, it looks clean even after one year.
Yes and most importantly no coolant or transmission fluid leaks detected. I had my service advisor confirm this when I got an oil change last week. He said the area looked bone dry when they had it on the lift.
Nice I hope everything stays that way... I'm seeing a tiny exhaust leak just fyi on the passenger side on the I used my terminator eye that's going to rust.
Maybe send a sample of your oil in to be analyzed?
These engines have been in the "news" alot lately
What about the oil?
Everyone with a 2020 needs to check for tranny oil leak at the trans cooler seen from the drivers side door underneath. It'll be wet and maybe dripping oil if you have that problem.
Overall, I am impressed at the quality of the suspension components. Pretty stout and high quality. I've seen pics of a Telluride suspension and didn't think it looked as robust. The rear suspension was something new to me, glad someone posted tips on how to change the springs in the rear. Front and back lowering is pretty straightforward on our cars, about 3 hours for a DIYer.
View attachment 325568View attachment 325569View attachment 325570View attachment 325571View attachment 325572View attachment 325573View attachment 325574View attachment 325575View attachment 325576View attachment 325577View attachment 325598View attachment 325599View attachment 325600View attachment 325601
Hey I just got a 2021 platinum with 3.0 and see there's a recall not done on the rear-end bolt. So call and set up an appointment. so I looked under mine and it only has the one bolt set up. Do you know why? I would think the two bolt set up is better.
Welcome to the Forum Clark. :wave:
I believe that Ford has continued with the 1-bolt system on the Explorers and said that they have "strengthened" the parts used. My previous '20, '23 and current '25 Aviator(s) all had the 2-bolt system. Not sure why the difference.:dunno:
The 2 bolt system is stronger. Ford with their infinite wisdom decided that instead of addressing the problem they caused by eliminating one bolt, they would do a software patch which automatically engages the parking brake every time the vehicle is turned off. This is to keep the truck from rolling away should the one bolt break, and the rear driveshaft seperate. I have read in other groups which are more centered on performance modifications that Ford actually de-rated the torque output from a standing start to put less stress on the one bolt rear crossmember. Of course, good luck proving that.wo
It really blows my mind that on a 400HP vehicle they would choose to support the rear of the differential with one instead of two bolts which is how they were originally designed. It would have been an easy fix for them to go back to two bolts on all the 400HP Explorers, but of course an extra bolt and an extra bushing costs "extra money".:banghead:
This thread shows one of the aftermarket fixes which helps support the rear differential:
There are a few different companies which make their own versions of this.
Echoing Rick's message; Steeda's brace is great. If you're a budget conscious owner like me, AWR Racing's brace and JXB's bushing support are also great solutions. Here is my writeup on AWR's product: 6th-Gen Explorer Differential Setup & Why Bracing Matters
Get AWR diff brace + JBX bushing support , and a Hardened single bolt 🔩
