Nope, no chance of going back once you're there.
What do you think of me wanting to fit 35's? You think it's possible with your spacers added to my rig plus trimming?
I'd like to fit 35's as well, but I worry about how much "trimming" may be involved.
I know it can be done... and will get there eventually myself, but only after i get the X lifted another couple inches.
To answer your question... I'm sure it's possible... I just don't know how clean it would look, I'd hate to see you hack up your truck.
But we'll never know if somebody doesn't try it right?
I will be trying it, but it'll be after a bit of body armor... so not till at least spring.
Although we get a bit redneck sometimes down here in Tennessee. So we'll see...
I think you'll have issues with the rear running 35's. Measure the gap between the front of the rear tyre, and the front of the wheel well. Then subtract 1" for clearance for suspension compression/extension, then multiply the result by 2 and add it to the diameter of your current tyres; I think you may end up rubbing.
eg, I am currently running 31.6", if the gap between the tyre and wheel well is 2.5" (I haven't measured - just estimating), then the available "safe" space I have is 1.5", which means you could go to a 34.6" tyre (31.6" + 2*1.5"). So I suppose 35" might just be OK.??
We do that over the mountains in North Carolina too. One time several years ago a guy in a Geo Storm was revving his motor at me wanting to race at a stop light. I had a Suzuki Grand Vitara at the time. I just rolled my eyes and let him go. He floored it and pulled couple car lengths ahead of me as I eased off the line. Once he was ahead where I could see him I noticed that he had one of those small temporary spares on the back of his Storm along with some custom bondo work. I looked at my buddy who was with me at the time and we both said at the same time "only in Lenoir".
No, I didn't. According to my GPS, my speed at indicated 100km/h is actually 103km/h on the 265s - not enough to worry about really. I actually found that with 255s, the speed by GPS matched the speedo exactly.hey when you guys bet bigger tires do you get your speedometer recalibrated, and if so how much does it cost.
I bought RB lift for my 05 and plan on getting 265
Thanks
Chris
Thanks
Chris
I wonder how much body work would be needed to get a set of 285s to not rub with only the addition of 2" spacers up front. My dad does paint and body work so I could get someone who knows what they are doing to do it. I wonder if it would look wrong even if it worked though.
So, bottom line RB doesn't suggest running 285's with the 3" spacer lift. So I trust his judgement. I'll go for the 265's ...
