- February 8, 2003
- Sacramento, CA 95827
- 1992 XLT
I think you can tell with the TSB, but I think bonded plates came into play in 98 or so. I am unclear as to why the 4r55 used a different EPC.
Tom... one thing you might want to consider, since the EPC can be added without dropping the VB is NOT to replace the EPC this go around, and see if the rest of the things fix the problem. If they do you saved yourself $250. 75,000 miles is low miles for EPC failure.
I'd put in a drain plug if you choose this path so you can do a less messy job if you need to go back in.
