3.0 ranger help | Ford Explorer Forums
3.0 ranger help
rob6045
lynchburg va.
2001 ranger. 3.0 litre
2001 ford ranger 3.0 wont start at times.
if truck sits for days the first key cycle you dont hear fuel pump run.
i cleaned throttle plate tps switch.
cycled key fuel pump ran.
waited 2 hours cycled key started vehicle truck ran for a minute then shut off.
cycled key off waited a minute cycled key back on no fuel pump noise.
safty roll over switch has never been reset and wouldnt trip unless vehicle rolls over.
i've swapped relays around in power distribution center still no help.
if i power the fuel pump manually vehicle runs.
could crank sensor or camshaft sensor effect fuel pump relay?
help please
Have you tried swapping out the fuel pump relay?
..Is this a flex-fuel vehicle?
Your location under your name may get others near you to chime in...;)
yes i swapped relays.
