Motoarzan
- May 25, 2013
- Cambridge, Ontario
- Explorer Sport 2014
Is it just me or does it take "forever" for the 3.5 ecoboost engine to warm up?
The past 2 winters I swear there's got to be a problem with the engine thermostat or something.
On a day where it's let say -10c (14 F). I can have the remote start running the vehicle for 10min first and then go for a drive half across town lets say 10k (6mil) or so through stop and go traffic and the temperature gauge on the dash still hasn't even reached it's midpoint/setpoint. This is all while having the inside air on recirc. and the fans on low robbing as little heat from the engine as possible.
For those in colder climates are you finding the warm up unusually slow as well?
Also, I have purchased a bluetooth OBD tool that I can plug in and display a live graph of the engine coolant temp on an iphone app. What I have found is the engine temperature setpoint tops out at around 87C (188F). Meaning the thermostat should stay closed and and not pull cooled fluid from the rad until it hits that setpoint.
However; as I drive and watch the graph of the engine warming up it seems to hesitate between 45-60C range, (113-145F)...in this zone you can actually see the graph level off for an extended period of time, the temperature even decreases a few degrees.
To me this is indicates the thermostat is opening prematurely and letting cold coolant in and holding the engine temperature steady and/or temporarily decreasing it.
This is even more significant on the coldest of days. I remember last year when it was around -20 the dash gauge got up about a 1/3 the way and then all of a sudden went "down" quite a bit to around the 1/4 mark...Eventually if you drive the vehicle long enough and as the rad coolant heats up the vehicle will reach it's normal operating temp and stay there but when it gets cold out it takes forever.
This winter has so far been mild but when it gets really cold out I'm going to post pics or a youtube video showing the temperature graph as the engine warms.
Anyone have any thoughts?
