3.55 rear axle ratio | Ford Explorer Forums
cole01
Dryden
1986 Bronco 2
would a 3.55 rear ratio axle work with a 3.50 front ratio :confused:
Yes very well off of dry pavement. I am no expert, but I have heard of it, long ago. It is common long ago to have slightly different ratios F/R, that is about the limit which you mentioned. If the tires are typical big knobby treaded things, it wouldn't be noticeable at all. It only makes a big difference if you get on traction closer to pavement and tread like a shallow street tire. Regards,
