- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
You've made a lot of progress, staying at it is most important.
I'd remove that rear intake piping, that isn't needed and it'll create an air pocket. Older intakes had the extra water ports and the ones on the right OEM used for heating the TB etc. Just put plugs in those ports.
I hope you can get that oil pan to work, the Explorer pans are ugly shaped on the bottom to clear the diff.
What WP and pulleys do you plan to use? Only the Explorer and 94/95 Mustangs are short enough to leave room in front for a radiator and thin fan. The older pulley systems are a lot farther forward, almost 3" I believe.
