I don't even have the lift and the BFG AT/KO's work fine. The only time the tires rubbed was on very tough rocky climb. The road was very uneven and washed out and we had to go up over a large boulder causing us to lean heavely to the left. When I got home there was only one place you could see where the tires had rubbed, and that was inside the left rear wheel well against the body, unfortunatley rubbing off the under coating so you can see bare metal.
