351 c or w??? | Ford Explorer Forums
351 c or w???
ex91
wingham ont, canada
98 ranger ex-cab xlt
its not an explorer but it is a ford!!!
im looking at a 73 mustang with a 351 v8 but the people that own it don't know with it is???? it and auto.
the only reason im buying the car it cause its cheap and if its a 351 c it will blow the doors of my brother 68 firebird(350-4-speed)but a 351 w wont(i don't think)?. any way it you know the ancer tell me.if it is a 351 w what can i do to make it fast?????.
people would you buy my explorer its an 91 xl 4x4 and it is cheap so buy it .
mike
The easiest way to tell the Windsor and the Cleveland apart is by the rocker arm covers. Providing they are stock! The Cleveland cover has a raised area on the end, where the oil fill hole and the PCV are located and each cover is held down with 8 fasteners. The Windsor is flat all the way across the top and it is held in place with 5 fasteners. Another way to tell it that the radiator hose/t-stat on the Windsor enters through the intake, where as on the Cleveland it does not.
As for getting better performance from the Windsor, start with a good dual exhaust, aluminum 4bbl intake and carb, headders, electronic ignition and a free flow air filter. Is that isn't enough try a good valve job with some mild proting and polishing and while its appart drop in a new cam and good timing chain.
Good luck beating that stupid Bowtie!
