psychotic said:
how hard was your supercharger install? Few/little modifications, direct bolt on, lots of stuff different??? and what $$$ range did that cost you?
It was not to hard at all. AED suppies you with a pretty detailed 20 or so page instruction manuel on the entire process. Had to cut and refinish some vacum lines at back, splice two lines from the MAF to the new air temp sensor on the plenum. Mount the radiator and electric pump for the air-to-water system. Got some voltage from one of the fuel injectors to supply the electric water pump. Re-route most of the vacum lines and lost some as well. Wire up the new injectors. Those little details are what take the longest. The rest just basically bolts right on. Lose the stock intake and this takes its place. Very clean and factory looking.
One has to make sure all the lines are clear from heat and moving parts etc.
It also came with and SCT Xcalibrator to reflash the compter. Once it was all finished we flashed the computer.... and vroooom.
A bad MAF connection leaned out my A/F and carboned two piston rings and lost compression in those two pistons. I was just going to rebuild with the stock pistons/rods becasue they were in such good shape... but then I decided to forge the bottom end and never look back. Besides the stock setup won't handle 9psi.
An experienced mechanic can probably do the tranformation in 8-10 hours. We took like 4 days, 6-7 hour days. But we took our time and made sure everything was put together nicely. If we had to do it all over again we could do it in about half the time.
Its a REAL nice system and can last for 150,000 miles easy. The system contains: the charger with 6psi and 9psi pully, 30lbs injectors, 70mm Throttle body air-water intercooler, electric pump and all the hoses and wires needed. AED put this on many 100% stock explorer and mountaineers and had excelent results, with 6psi.
The entire system put me back about $4,500 and that included shipping (110lbs) and the SCT hardware.
The bad news? AED (Allen Engineering Designs) went out of business. Closed Dec 04. I beleive there is another distributor around somewhere. Or maybe just direct from Eaton.
Well depending on how my future goes as far as work. Time will only tell when I take the extra dive into the motor and go really crazy. If I do I will definetly put my supercharger for sale here.
What future mods do have have in mind or lined up???
