- December 28, 2010
- Russell, Ontario (Ottawa area)
- 2023 Aviator Reserve 201A
- Callsign
- VE3
Okay, I tried my cargo area dome light. I got into the vehicle and waited for all the interior lights to go OFF. Then I turned the dome light ON and was able to turn it OFF. Got out and waited for the interior lights to go out and they did, including the dome light. That is the way it is supposed to work is it not?
In reading one of the posts it seems that the dome light was turned ON by its switch and then the door/liftgate was closed and the light stayed on. This is what I would expect it to do since it wasn't turned OFF with its switch before closing the door/liftgate. It is no different than turning your map light on and then closing the door. The light will stay on because it was switched ON. In either case, the lights will turn OFF automatically after 10 minutes when the Power Saver feature kicks in. Unless I'm missing something I don't see a problem here.
