Sounds like the gear mechanism is stripped you will need to replace the assemble part #6L2Z-7861383-AA its a common failure item with power third row seats! Amazon has it for $261.00 here is the link http://www.amazon.com/Ford-6L2Z-7861383-AA-LATCH-ASY-REAR/dp/B000NTU7BU... Good luck if you search around there are a few threads that explain how you can do it your self/
