KW021
- December 12, 2008
- Binghamton, NY
- 1998 XLT
I have been searching all over for many hours and days now and have come across some conflicting ideas as to whether or not I have a bad IAC.
I am having idle surge problems when my EX is cold (sits overnight and below 40 F outside). Somtimes it stalls if i don't give it gas for a little bit, but it always sputters enough that the whole truck is shaking. When it warms up a little bit the idle evens out and its fine. Once and awhile it will surge when its warmed up but not to often and its very minor. I have also noticed a loss of power and drop in fuel economy since the check engine light came on...I get roughly 17mpg, I accelerate slowly and set cruise at 66mph on highway to save as much gas as I can.
I tested the IAC and passed 2 out of 3. Voltage from the wire harness was good and the ohms between the 2 pins on the IAC was 9.5ish. When I did the test from one pin to the IAC casing and it read OL...so I figured the IAC is bad. Then I read something else about unplugging the IAC to see if the idle changes. My EX stalls out immdiatelty when the IAC is unplug which from what I read means it is functioning properly.
So I don't know if I should spend $85 on a new IAC or not.
So far I have replaced the Fuel Filter and MAF sensor with no improvements. I have also sprayed some carb cleaner around a bunch of vacuum hoses and haven't been able to find a leak yet.
I'm not sure how old the plugs and wires are and I don't know if the manifold gaskets where ever replaced. It has 72K miles and i bought it from original owner who seemed to take good care of it.
