burre
- January 2, 2007
- Grand Forks, ND
- '00 XLT
I have a 2000 Explorer XLT with a 4.0 OHV. I just recieved the XCal2 from Bama Chips. With any of the 3 modified program, the engine idles and runs very rough. It sounds as if it is only running on 4 cylinders. Also, it does not want to pull past about 2500-3000 rpms in gear. By the way, it has an auto trans. It runs perfectly normal with the stock tune.
Is it possible I got programming for the sohc or 5.0? Otherwise, is there something else I can try? I pulled the fuel pump fuse like the directions said. Would it help to disconnect the battery after installing the Bama Chips tune to reset anything?
Thanks alot!
Eric
Thanks alot!
Eric
