rhauf
- November 1, 2005
- Ca
- 91,93,98,&02 Exploders
so my '91 has developed a problem.. and i can't quite put my finger on it.
it's always taken a bit of cranking to get it to start after it's been sitting for a while. so that may or may not be related.
the problem is, it stumbles a bit when i hit the gas, and if i give it more than about 1/4 throttle it starts surging and stuff (almost like a carb'd car running out of fuel or with a clogged fuel filter) and i'm baffled at what the problem is.
so far i've replaced the fuel filter, TPS, and MAF, and nothing has changed. the check engine light is not on.
another thing i noticed, was last time i went wheelin' with it, i was on a fairly high trail (about 6,000 feet elevation) and it was a hot day (100 degrees) and after i climbed up a bit of the trail i shut it off to help my friend tip his truck back onto its wheels... when i got back in the explorer it didn't want to start, seemed to be vaperlocked (i was getting what appeared to be just fuel vapor out of the fuel rails shrader valve, along with some spurts of fuel) i let it sit for about a half hour and it fired up. this was before i started replacing parts.
