4.0 splined camshaft separation | Ford Explorer Forums
mike1064
lincoln ne
2006 ford explorer
I have a 06 explorer that I have had the camshaft separate twice and allow the cam timing to slip and bend valves. I have never seen a splined camshaft before, even bought a new one from Ford and it also separated, not sure if I the oi pressure it too high and the tensioner puts too much pressure on the cam and walks it out, or if somehow I am binding the the camshaft, please let me know if anyone has ran into this before.
usually bending valves happens when the chain slips from lack of tensioner pressure. odd that it separated though, thats not supposed to happen. im doubtful its the tensioner however? welcome to EF!
I rebuilt the engine as a reman was not available at the time, I did put a high pressure oil pump in, but I don't know why the camshaft separated like this, and it looks like the slippage was in the splines and not caused by low oil pressure
It was brand new from ford, lasted about 1 minute of run time
.. I wanna hear what some of the other members say and think about this
That is interesting, What is the torque spec you tightened the bolt on the face of the sprocket to?
Last time I saw this happen someone swapped cam sprockets left to right. The offset on the gear is different.
they were marked left and right on the cassettes but they are aftermarket cassettes, and i dont have any problems with the left bank.
Which way did the bolt turn to tighten?
Yeah it looks like you have the thicker one on the back like it's supposed to be. How about Josh's question, was it left or right hand thread on the gear bolt? I'd assume if you bought a cam from ford they'd give you the right one.
Can you take a wider pic from overhead? How about looking down the chain guide, is it lined up when the gear pulls out?
I'm at a loss, the parts are correct. Not sure what else could fail to cause this?
So after the splines pull out it is lined up in the guide or at initial install? That's a solid 3/8" gap on those splines if not more. The jackshaft gear is pretty skinny so even if you put it on backwards it would still line up in the same plane. I need more pictures to shed more light
Mike, did you figure anything out? I experienced the same issue about a year ago with my 2011 Ranger. It ran less than 1 minute. I am just now revisiting the problem. I pulled the engine and inspected the rear timing components. All looks ok. I suspect my method of torquing the rear jackshaft bolt lead to this problem.
How exactly did you toque the front and rear jackshaft bolts. Do you have all of the tools including the rear jackshaft sprocket wrench?
I don't want this to happen again. So I'm trying to figure out what went wrong.
Do you have a picture of the gear you had on there?
Here are pictures of the gear set. It is from an aftermarket Cloyes kit. I read a thread a long time ago where someone installed the spacer backwards causing this problem. I installed it with the taper facing forward. That should be correct?
IMG_20221127_192110925.jpg IMG_20221127_192129784.jpg IMG_20221127_192049228.jpg IMG_20221126_095054495_HDR.jpg
