Don't have a pic at this point, but I think it would be worth it. Stock piping should be 2.25" assuming you have the V6 4.0L. But the V8 should be 2.5" if I am correct. I have 2.25" piping and put a 2.5" in/out muffler on, no problem. The thing is now that I have done the muffler, I have the fever! I am looking forward to replacing the entire system with 2. 5" piping sometime. Assuming you would be subject to the same situation, it would be cheaper to just go ahead and replace the entire thing since I will have to pay to run the pipe and then I will be out $40 for the original install. However, it is not necessary to replace any piping, so it is ok to leave it as it currently is. As for the y, I know that most exhaust companies do make various piping pieces, so you should look at either Jegs.com or summitracing.com or some similar site for those pieces, but if it was me, I would just have it run from the back of the y or even from the back of the cats. Hope this helps,
Kendal
