fowledup
- March 4, 2022
- coushatta, la
- 2005 explorer 4.0L
I've done a complete timing job on my daughters 05 4.0l sohc and I not only used the correct tooling but even have alldata on it, who was aparrently as confused as I am, as i found a few mistakes in their guide. when torn down, both the cams seemed to be pretty close if not perfectly in time, guides in place and undamaged, however the balance shaft chain tensioner and guide, were shattered. Got it timed up and installed only to be disappointed with a no start, which upon checking all the usual suspects, I determined it must be the pass side being out of timing because driver side all three hitting perfectly...... pass side straight misfires from all three cyls.... nope I checked and rechecked and timing seems right. So my question is this..... is the timing at the camshaft so touchy that even with the proper tooling it can still be off so bad all three cylinders on that side have zero compression and/or does the 4.0 sohc tend to have issues with bent valves or the heads warping or leaking head gaskets that is more likely the issue?
Thanks in advance.
Thanks in advance.
