tf43
- July 10, 2010
- American Samoa
- 2000 XLS X series VIN
Ok...perhaps a stupid question, but need to ask, and hope you guru's might help some.
My search on the ole inner web, as gas monkey might say...isn't helping me much.
Question: is there a major difference in the timing cover housing used on the SOHC and OHV 4.0L engines?
I have a 2000 Explorer that is a OHV engine, so I believe as the cam is in the block, and not over the valves.
The VIN is: 1FMDU62X0YUB67722, and a look up says it was a SOHC engine, but I know for sure it does not have the cams over the valves. I need to replace the timing cover due to a water leak out of the driver side jacket...eaten through...go figure...thought I needed a expansion/freeze plug...wouldn't be the first time for that either, but this is the timing cover. Anyway, can you folks advise if they are different, or pretty much the same in design between the two. And if you have pictures of either...huge help too. I've only removed the AC and PS so far to find the leak and closed the hood for now. I live in the South Pacific and parts are not simple to come by locally either. So the hunt is on and just wish to know about the thing some.
Thanks for looking and any advice you might have about it all.
