4.10 gearing with LSD | Ford Explorer Forums
blacktjsport
Richmond, VA
93 XLT
Is there a standard model that came with the 4.10 gearing?? Having the limited slip differential would be a bonus too. Thanks in advance,
--Matt
the axle code is a D2 --- when your lookin at a explorer....look on the door to see what axle code is on it. You want a D2
-Drew
Just beware that if the limited slip has alot of miles on it the clutches will be shot.
If you are wanting a limited slip you would be better off buying a new one and new gears as well.
Ranger, FX4 Level II 4.10 axle ration with a Torsen limited slip. I beleave that 4x4 edge models have a 4.10 ratio.
The FX4 is a 31 spline as well instead of the 28 spline.
I don't know if the Edge is a 31 spline or not.
