Dean peulen
- August 31, 2022
- Brisbane
- 2002 Ford explorer XLT
I had oil leaking from my 2002 4.6 Ford explorer oil filter housing this is a common failure by what I have read . I changed the gasket and found the to centre bolts bottom out before they engage the housing and there is ruffly a 2 mm gap very hard to see because of there position. The two outer bolts pull down correctly . I believe this is a factory fault that has caused the constant failure of these gaskets . I asked for a response from Ford Australia only to be sent a picture of the oil housing and no comment on my technical queries . Can forum members please keep a eye out for this fault and see if it is a universal problem. If so Ford sould be responsible for rectifying this fault. I placed washers under the two centre bolt heads . Two required on each bolt to get them to engage the housing and gasket.
