LMHmedchem
- October 28, 2011
- 2002 Explorer XLT v8
Hello,
I am getting ready to restart my truck after an extended time sitting. It took forever to get the parts I needed for repair and as a result, the truck has been sitting for quite a while. There was no oil in the pan for a good bit but my understanding is that doesn't really change things for the upper engine where the oil drains out into the pan anyway. I have a new battery so that should not be an issue.
At any rate, I am going to start it up again soon and am thinking that I should implement some pre-oiling procedure or other. I know this is not a case like reinstalling a rebuilt engine, but I still think it makes sense to get some oil pressure going and get some lubricant in there before I try to ignite it. I have read a number of options such as removing the fuse for the fuel pump, removing the connections for the coils, removing the spark plugs, etc. I have no means of evaluating theses suggestions. Is there some procedure that I can give a try that will get some oil into the top of the engine and some pressure into the timing chain setup before I start it up?
(or at least try to)
I am interested to know what everyone thinks about this. Am I overthinking it?
LMHmedchem
LMHmedchem
