ashleyroachclip
- February 24, 2004
- Roseburg Oregon
- 1991 Explorer EB
I have a 94 Ranger , 4.0 4x4 , everything works , but my question is ,
At times I can see the small indicator , beside the switch , is faintly glowing , while in 2 wheel drive.
When I engage 4 high , the light glows brightly .
There is no problem with the low range indicator lamp .
everything works as it should other than at times , when in 4 high , it seems the vehicle is disengaging from 4 back to 2 wheel drive , tho the indidcator lamps remain on .
This happens only in high range .
Another thing I recently had happen , is I was in 4 high , had stopped to let the dogs out of the rig , shut it off , started back up again , and I was no longer in 4 wheel drive .
Lights were off .
As soon as I pressed the button , It engaged as always .
This has happened a couple of times this last year .
Any one have a clue as to what is going on here ?
any insight is appreciated .
Ashley
Lights were off .
Ashley
