Thanks Paul,
Rick, Those springs are 4" lift springs, skyjacker softrides. so the spring over and the leafs give me about 10inches of lift. About half of the shackle will be cut off, those are ajustable shackles and when I find the right hole I will cut the rest off. The spring mounts on the axles are wider then the frame, so I have to widen the frame in the front and also in the rear the other reason why I had to lower the front down so far, was because the frame sits a lot higher in the front then it does in the rear. and you wanna have the spring mounts level.
I could lower it down a bit, but why do that when it's so fun to be big.
I have been thinking about getting a little bit smaller tires, maybe the 42" swampers, or the 39'5 bogger, what do you guys think about that ? For me to be road legal I will have to make some pretty heavy duty fender flares, unless I get smaller tires or I could get a dana 60 cut 4 inches off the right side and that way the spring mounts would match the frame. This project is comming along, and the only thing left is just the lose ends.
Thanks guys and all the best,
Oknut
