B o n e H e a d
- December 7, 2008
- port huron, mi
- 99 ranger
Hi!
I've got a 99 ranger with 95000 miles with the 4r44e trans that has no reverse gear (acts like it's in neutral). Low 1 gear works fine (but I didn't test compression braking) Fluid is clean, not burnt, maybe a little low (right at the lower hole when cold). No Check engine light, no dtc's with generic scan tool. I hooked up a pressure gauge and got these readings with cold fluid:
park: 135psi @ idle, same at all rpm.
reverse: 175 psi @ idle, pegs gauge when revved up
Neutral: 130 psi @ idle, same at all rpm.
Drive: fluctuates, 105 when first shifted into D, jumps to 170 then
down to 100 within about 2 seconds. then stays at 100.
when revved up, goes to 210 or more (can't rev it too high
without moving truck)
I don't know if these pressure readings are normal but they seem a little high.
I am currently letting the truck run to warm it up & then I will post warm readings, but if anyone has some insight or advice on what else I should check I would appreciate it.
Thanks!
Thanks!
