nicksails
- July 31, 2009
- deep east texas
- '91 eddie
'91 explorer 2wd. i've finally got back to my no 4th gear problem. after insuring voltage to the solenoids, i pulled the pan and found that the cast "block" that the end of the adjuster goes into is missing in action.
i can see the intermediate band adjuster, but the 4th was just the end of the threaded adjuster. i poked around with a mirror and a magnet, no joy.
it worked fine until it didn't. it's hard to believe my dirt road is so rough that it shook this loose. it seemed to shift fine, but must have been way out of adjustment.
now that i've found the problem, i have 2 questions.
1- i know this is near the front of the trans., is that how i get there? and will i need any special tools?
2- where can i find parts and should i try to get just the band or the drum as well? any seals that need replaced?
ok, 3 or 4 questions. the fluid looked new, the filter clean. there was some "metal powder" on the magnet but nothing even 1/8 the size of a pinhead.
trans worked perfect until no 4th. and i don't have the guts to go any farther.
special thanks to brooklyn and glacier for the post, links and photos.
thanks for any help,
nick
nick
