Cstoliker
- July 19, 2008
- 2000 Explorer XLT
95 Explorer XLT Manual transmission. Just bought the truck. The 4wd and 4wdLow lights flash 6 times every couple of minutes. When I first got the truck nothing seamed to happen when the selector was moved from 2wd/4wd/4wd low. I disconnected the battery and now when I put it in 4wd the 4wd light comes on like it should sometimes, other times I need to shut off the truck, select 4wd then start it again for the light to come on. With the light on the 4wd does not seam to be working though. ( I took it off road for a quick test and got stuck rather easily) I can get it in 4wd low occasionally, the indicator lights do not change but the ratio does. Problem is when in low it starts out fine then hear and feel a Bang and it goes back in hi range.
