4wd still not working | Ford Explorer Forums - Serious Explorations
  • Explorer Forum license plate frames are available 2 for $12, or 4 for $17. For photos and more details CLICK HERE
Cstoliker
2000 Explorer XLT
4wd still not working. On my 95 Explorer XLT. After disconnecting the battery and clearing any codes the 4wd and 4wd low lights start blinking 6 times almost immediately after turning on the ignition before I even start the truck or moved the 4wd selector.
I recently fixed a vacuum leak and now the C.A.D. does engage the front wheels and the transfer case works using the Brown wire mod. (I have manual 4x4 hi if needed)
I just took apart the shift motor and verified the position sensor is working. (not lost) So by process of elimination only two possibilities remain?
1 one of the two Hall effect speed sensors is not working.
2 The Gem itself is not functioning.
Would a malfunctioning Hall sensor disable the 4wd before the truck was moved or started or would it wait till the gem got conflicting data from the Hall/ABS sensors? (When the truck was moving)
And if the Gem itself is bad would the lights blink? Is not the gem responsible for blinking the lights indicating a general fault code?
