jman_07
- January 7, 2008
- 01 XLT
Ok gueys so in my 2001 Ford Explorer 4.0SOHC its control trac of course so i dont get this when i lock it into 4wd lets say the front tires are on cement and the rear is on sand if i step on it especially around corners once the rear hits the sand the rear spins.
Now i thought that the front and rear axle are both locked together and the rear tires cant spin unless the front do.
I talked to a mechanic who told me its because its a viscous clutch? something like that he said its not a true locked center differential
He said it would be a risky job of welding something in the transfer case if u wanted all 4 tires powered equally in 4hi??
Is this true
Jared.
Is this true
Jared.
