307explorer
- April 26, 2022
- Fort Collins Colorado
- 02 Sport Trac
Hello old friends (old user, new account here)
I apologize if someone has covered this. I have searched up and down and have not found the thread I am looking for.
To start: 2002 Sport Trac 4.0 with auto 4wd
I had some issues with shifting into 4wd about a year ago, I replaced the transfer case shift motor and everything worked properly.
Last week I took my sport trac on a small road trip (<70mi) and when I arrived, I turned into a parking lot and my 4wd was engaged.
Nothing on dash, didnt hear it engage and felt it only at very end of the drive. At first I thought I had a slipping trans.
Turns out it is just stuck in 4hi.
I removed the shift motor and tried to manually shift back to 2HI, but the selector on tcase is stuck in 2HI. I cannot manually turn it to 4HI(vehicle itself IS in 4HI, selector on tcase is in 2HI)
I put the motor back on the electrical connector and it shifts properly when I change the selector on the dash. (shift motor working as it should)
So i put the tcase shift motor back on the tcase. I drive the truck, the tcase will go into 4HI on the dash and illuminate the light, and even into 4LO.
Also worth noting- It will actually put the truck into 4LO - Meaning the shift motor is working properly and that function of the tcase is working properly.
The one thing I cannot do is get the truck back into 2HI. Not manually, or with the motor installed. (motor, dash light, and relay all seem to be working properly)
Chances are the tcase will need to be replaced but after all the work I have done to this truck in the last few months I would really like to avoid a major repair.
Any ideas???
Also: it will take me a while to get one, and the sport trac is my only vehicle at the moment.
I dont see a problem with removing the drive shaft to the front diff, and driving it for a month or so until I get the new parts. Is there something I am overlooking?
Thank you for reading and replying folks
Any ideas???
