4x4 low light. I'm in neutral and brake pressed | Ford Explorer Forums
Powerstroke87
Tawas City
2005 f250 powerstroke
4x4 low light blinks approx 20 times and goes off. Brake is pressed and in neutral. Would the module cause this. 4x4 high I push and it stays on. Please help
It’s not actually shifting to low? Blinking 4wd light men’s there’s a code. Its possible to be a few things, including he shift motor being sticky and not making its position change.
I'll check codes again and see if its throwing anything. Let you know!
Most cheaper scanners won’t show transmission/abs/4wd codes.
