I can press the 4x4 High button while doing 80 on the highway.
I got some pretty significant clunks/shifting while shifting through gears in 4x4 low. Is that normal?
In order to shift into 4-low, you need to be in neutral and at a full stop. I strongly recommend reading through your manual (or downloading a PDF of it) and going through the operation of the various drive modes, and when to (and not to) use them.I have the exact same problem. Any solution yet??? Anybody??? 4x4 low button flashing 20 times 2002 Exploder XLT
That question was clearly answered in post #2 of this thread.I have the exact same problem. Any solution yet??? Anybody??? 4x4 low button flashing 20 times 2002 Exploder XLT
My 2005 Explorer 4x4 t-case 4 low kept blinking so I went and followed you instructions and bigolly it workedif you are just trying to go to 4 low you need to put the truck in neutral and hold the brake pedal, then press the 4 low button, other wise the transfer case will not make the change
I have a 1997 Explorer that had the same problem recently 21/2 months after I had a the drive shaft from the transfer case to the front differential seize and break one of the end connections. I had my mechanic check it out and ask him to service and drain the front differential and the transfer case while investigating the problem. The problem turned out to be the the rear driveshaft speed sensor was old and dirty with metal wear dust. This sensor is also magnetic which is what attracts the metal and that is what they said causes it to come on and flash 6-10 times and then go off and then 5 or 10 minutes later while driving do the same on and off blinking again. When they cleaned the sensor and completed the service all was good again with no flashing on and off. However since the sensor was 20 years old I had them get a new sensor to replace the old one. The cost of the sensor was $95.oo and labor $58.oo. in the last 6 weeks the flashing light has never come on. Problem solved.I have a 2002 Ford Explorer. The 4x4 Low light blinks approx. 20 times when I press it. Can anyone tell me why and how to fix?
