spt87
- September 17, 2019
- Sandwich
- 2002 Sport Trac 4x4
Hi all - I've looked thru many older threads but not found anything on this.
I have the 5 spd manual transmission on my 02 sport trac. To shift into 4wd low the tranny needs to be in neutral and the brake pressed. I'm doing that but it won't shift into 4x4 low. I've tried with clutch pedal pressed/not pressed as well. Shifts into/out of 4x4 high fine. I would suspect the shift motor but in my experience that would typically affect shifting into/out of 4x4 at all (high or low).
On the manual transmission, is there a sensor/switch indicating back to the GEM/shift controller that it is in neutral? I'm thinking that may be the problem as I had a rebuilt transmission put in the truck a while back and I'm thinking if that was not plugged in during the install. I rarely use 4x4 low but recently had a need for it and noticed the problem. If there is a connector for it anyone have a rough idea where it is? Thanks.
