4X4 rewire | Ford Explorer Forums
4X4 rewire
david macdougall
NORTH PORT
1998 ford explorer
Has anyone ever rewired the Transfer case to toggle switches. It seems like I just need a switch for the front drive magnets and another for the Hi/Low motor....tired of banging my head against the wall trying to get the factory system to work. Dash indicator lights are flashing when started and getting nothing from 4X4 module. When jumping Actuator, its turns from Hi to Low just fine. I'm assuming the wire running into the Transfer case is for the front Differential Magnets. Any thought appreciated... Vehicle is a 98 with 4.0 and 3.55 non LS
your truck has the 4auto position on the dash switch? Control trac AWD?
There is a guy here from Canada with an Explorer on snow tracks recently, he had his t case setup to run with some switches. I had never seen this before.
You likely need a shift motor or to open up your control trac t case and fix it.
