kmmac1705
- August 13, 2006
- Tennessee
- 91 E.B. 4x4 Explorer
I rebuilt shift motor and replaced bushing put it in and it worked. Then it went out and I tried checking to see if it turned and unaligned pins. It didn't. Today got up went to store on cold run pushed button ( just for heck of it ) and it worked. Then on way back from store it didn't . I checked continuity between pins. Shift motor works wiyh applyed voltage. I read something about a vacuum line but don't know anything on it. I can't figure out white button on computer in cargo area ( mine won't push in or pull out ) I read it is supposed to be a reset or tell you if computer is messed up. I read something about servos and trans fluid in them. I found some trans fluid on the ground and on skid plate.Could any of these make it work then not work. OH by the way it is on a 91 eddie baur. If anybody can help please do . I'm about to drive it in to the mighty mississippi.
