CougarX
- February 7, 2000
- Louisville, Kentucky
- '98 EB, '02 ST, '97 XLT
After offroading the other day my transmission began to give me problems. At first it would not idle in gear unless you gave it a little gas to keep it from bogging down. It acted like a manual when you don't give it enough gas when you let out the clutch, it would just seem like the transmission was dragging it down. It was fine in park and neutral but wouldn't idle in gear. After i got back to town and drove a little more and brake torqued it once for a couple seconds it was fine and drove like new.
The whole next day(saturday) it drove fine, no problems at all, no stalling or anything. But today it started acting up again. Now, instead of dieing when in gear, it jerks down into 3rd when you coast in overdrive. Its fine as long as you've got the gas pressed some but as soon as you let off to coast it jolts into third very hard and for a second, then shifts back into overdrive, then does it again until you get slow enough to stay in 3rd. Sometimes when I accelerate with about 1/3rd throttle it'll jolt shifting between 2nd and 3rd and then 3rd and overdrive, but not al the time. The truck is still driveable but its very annoying anytime you coast.
I've checked the fluid level, checked the linkages, and there are no CELs. What could be wrong with it?
